Brief Description: Flap drive + tailcone cross members
- Took about 45 min to create the 2nd flap drive block. That was 1/2 the time it took to make the first one. Experience helps.
- Had my wife help me flip the fuselage right-side-up so I could work on the channel cross members.
- Used 2 large squares to sqare everything up. It took a long time. There was no way I could see to square the whole thing up at once, so I started at the middle cross member and worked forward.
- Pilot drilled and cleco'd all 3 members.
Tomorrow I'll add the last cross member (exclusive of the pieces that go in at the very tail, as the tail wheel hardware goes in).
The 2nd of 2 flap drive blocks
Flipped over the tailcone and added 3 cross members
