Michaels Web Site
Sonex Standard Gear
Fairleads & misc
Misc stuff tonight:
- Lightly sanded then cleaned the wingtips that I prime painted last night
- Drilled the rivet holes for 2 more fairleads. Need to have a better setup on the drill press before drilling the larger holes.
- Installed the snap-in bushings in the vertical channels of the tailcone.
- Started making one of the assemblies on F10
Fairleads ready for the 3/4" holes
A double-angle assembly from F10, stuck together w/double sided tape and clamped.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
