Michaels Web Site
Sonex Standard Gear
RIGHT flap construction
- Set the rest of the ribs in place, pilot drilled, and then updrilled, on 2 of 3 faces.
- Deburred and reassembled.
- Flipped flap over, closed skin over ribs (photo #2), then pilot drilled and updrilled.
- Once again used one of my metal straight edges for the hinge offset (I cleco'd the skin to the work table to hold it flat), per photo #3.
- Once again used double-sided tape to hold the hing in place while drilling. Got about a dozen holes drilled to hold the hinge in place.
2 of 3 sides of all ribs updrilled
Getting ready to close the skin over the ribs, to drill into the ribs on their 3rd side
Hinge in place with offset, held in place with double sided tape for drilling
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
