Michaels Web Site
Sonex Standard Gear
Begin work on ailerons
Started work on the ailerons.
- I already had two over-sized sheets all polished up and ready to go.
- Calculated the bend locations based on the Z-stock control surface dimensions
- Marked the sheets for the X/Y dimensions and the bend locations.
- Cut the sheets to size.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
