Michaels Web Site
Sonex Standard Gear
Landing light lens install
Per the previous log page, here is the "bottom" mounting bracket assembled with the 3 nut plates installed, and finally with the lens installed.
I still need to get flush screws to replace these temporary ones, and I need to install the foam tape that came with the kit.
The "bottom" mounting bracket with the 3 nut plates.
The installed lens. The screws sticking up are temporary until I get flush screws.
Another view of the "bottom" of the lens assembly.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
