Michaels Web Site
Sonex Standard Gear
RIGHT wing tip (tip rib)
Worked on the right wing tip (tip rib):
- Installed 4 nut plates and installed the wingtip light pod
- Cut and trimmed the fiberglass wing tip. It's nearly ready to set in its final location so I can drill the rivet holes.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
