Michaels Web Site
Sonex Standard Gear
RIGHT wing root doubler + riveting
- Finished dimpling and updrilling the root doubler and the associated wing skins/ribs.
- Riveted along the entire length of the top spar cap.
- Installed all flush rivets in the top surface of the leading edge skin, and about a dozen standard rivets at the upper aft skin.
Dimpled areas at root.
Length of spar + top surface of leading edge skin with all flush rivets installed.
Typical flush rivets.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
