Worked to finish the installation of the wingtip light pod.
- With the pod taped down, drilled 4 holes thru pod and into wingtip
- Installed 4 nut plates. I was brain-dead when I intsalled the forward one (photo #2), orienting it horizontally instead of vertically. Fortunately the pod (green line) covered the forward rivet, but it was close.
- The hole in the wing tip is for the light's wiring
Then took off the leading edge skin and began the process of locating the wing walk again, so I can next bend the root doubler around the leading edge of the rib.
Rivnut cleco'd in place. I used a long drill bit to drill the two wings.
Green is the final location.
Screwed in place (10-32 x 3/4" stainless steel screws)
