Michaels Web Site
Sonex Standard Gear
LEFT wingtip install
Installed the wing tip (actually it's called the "tip rib", but it's not really much of a rib).
- Held the tip in place with blue painter's tape.
- Pilot drilled all the holes.
- Updrilled all the holes to final size (according to the Sonex instructions, no need to countersink the rivets on the leading edge skin.
- Located and taped on the wingtip light pod (they are GuagePods, made for the Sonex).
http://www.gaugepods.com/aircraft.html
- Put the tip ribs side by side and located the RIGHT wing tip pod to match the left wing (photo #3).
- Drilled a hole in the wing tip for the wires for the lights.
- Turned the wing over and deburred all the wingtip holes.
- Then began planning the layout of the wing walk.
Fiberglass wingtip pilot drilled in place.
The "fits much better" leading edge.
The wingtip light pod, with the outline on the other wing tip.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
