Michaels Web Site
Sonex Standard Gear
Left Wing - Add rear spar + make root ribs
- Pilot drilled all the ribs at the interface with the rear spar.
- Then updrilled and cleco'd.
- Leveled the wing in preparation for installing the root ribs.
- Modified the root ribs per the plans (deburring and adding gussets will be tomorrow).
Rear spar updrilled and cleco'd in place.
Leveling the wing in prep for installing the root ribs.
Modifying the two root ribs per the plans.
Sonex Standard Gear Home
Aluminum Materials
Angle Parts
Bending Brake
Cowl
Finish-Polish
Hardware
Learning Point
Smoke System
