Michaels Web Site
Sonex Standard Gear
Wing root doublers + fuselage tunnel pieces
Cut out and finished wing root doubler W20-01R.
Rough cut:
- W20-01L, wing root doubler
- F16-02 & F16-05, fuselage tunnel (for wing spars) angles
W20-01R is the long skinny one on the right.
Two fuselage pieces (that need to be bent) on the left; W20-01L on the right and above.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
