Michaels Web Site
Date:  2-15-2014
Number of Hours:  0.00
Brief Description:  My Current Punch List
Here is the current punch list I'm working through:
Add cowl fasteners at hub
Test fit entire cowl
Finish fasteners at windscreen
Finish control surface cotter pins
Solid rivets in spar tunnel
Paint tail tips
Paint cowl
Storage compartment
Alum cover over pushrod
Wheel pants
3rd fastener on R pant
Install transponder antenna
Transponder test
Attached transponder connector
Test for static leaks
Have upholstery made
Fuel flow test
Test run engine
Rivet lower skins
Support wiring under panel
Fix oil return hose kink
Barber pole stripes behind fuel sight tube
Attach spring at canopy slide
Re-attach brake cables
Repair paint
Bulkheads
Finish setting rudder hinge
Install N-numbers
First polish back of fuselage
Replace nylon lock nuts with solid lock nuts in engine compartment
Seal firewall opening at electric wires
Mark fuel quantities on tank
Tail low
Tail hight
Buy ELT
Install ELT
Get State aircraft registration
