After getting all the tweaks done today I fired up the engine for the first time. It ran very well, and all the temperatures were in the green. The secondary timing is a little off, so need to adjust that slightly.
The only other thing was a small oil leak at the right side of the engine. I can't tell where it's coming from but appears to be either from the base of one of the cylinders or the base of one of the pushrod tubes. It was only evident from a streak of oil down the inside of the lower cowl, when I removed it.
Too windy to fly, and I had other things I had to do today.
