Michaels Web Site
Sonex Standard Gear
Hydraulic Brakes
Using the mark I made test fitting in the cockpit, I drilled a new hole by using the hole (not seen here) in the master cylinder arm.
Handle test fit to master cylinder
New bolts. The lower hole was the existing middle hole in the previous handle setup.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
