Michaels Web Site
Sonex Standard Gear
Trim, ELT, Prop, Mag
1. Removed the suspect bad (top) mag.
2. Removed the ELT to send it back to ACK. Something is not working properly with the wiring to the remote annunciator.
3. The black paint on the back of the prop already got a nick in it! So I primed and painted that little spot.
4. I also decided to try an alternate method to attach the trim cable to the trim tab. It's a b-nut.
New trim tab cable attachment.
From the other side.
Top mag removed.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
