Michaels Web Site
Sonex Standard Gear
Re-check upper plugs
I needed to check the upper plugs. They are harder to get to than the lower plugs, so I'd been putting it off.
I removed the side baffles, removed the plugs, rechecked/reset their gaps, added anti-sieze to the threads, and reinstalled.
I checked the plug connectors to make sure the conductor was properly installed, which they were.
Everything was reinstalled.
I took the opportunity to add more zip ties to stabilize everything and secure to the engine mount wherever possible.
Upper right plugs
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
