Michaels Web Site
Sonex Standard Gear
Finish control triangle
Finished the control triangle tonight. I drilled for, and installed, the AN3 bolt to fasten the control stick to the horn. Then the connector that ties the the two sticks together had to be located, drilled and bolted.
It's ready for re-installation.
Drilling thru the control stick and horn.
All cleaned up, with the hardware installed.
Assembly complete
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
