Michaels Web Site
Sonex Standard Gear
Trimmed forward "tabs"
Separated the two cowl halves, then used a Dremel cut-off wheel to trim the new "tabs." Then sanded them smooth and rounded the corners. Test fit, and they work well.
"Tab" trimmed about 1" above the cowl split.
Same on the right side.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
