Michaels Web Site
Date:  3-16-2014
Number of Hours:  1.00
Brief Description:  Misc fuel punch list items
1. Installed the fuel shut-off knob/rod (it goes through the panel and screws onto a rod-end bearing).
2. Installed the lower end of the fuel sight tube to the fitting on the bottom of the fuel tank.
3. Also attached the transponder connection at the back of the unit, and turned it on for the first time. Works! (Always make sure you have an antenna connected before you turn on ANY radio.)
