Michaels Web Site
Sonex Standard Gear
Finishing off the tail tip paint
Having made the repair to the ding in the right tail tip, I masked it an surrounded it with plastic again, and added 2 coats of clear coat.
Then I added 2 clear coats to the left tip as well.
The vertical tail tip needs a new clear coat, so that is all that is left to do.
Right tail tip repaired and clear coated.
Left tail tip clear coated.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
