Michaels Web Site
Sonex Standard Gear
Finishing off the tail tip paint
Having made the repair to the ding in the right tail tip, I masked it an surrounded it with plastic again, and added 2 coats of clear coat.
Then I added 2 clear coats to the left tip as well.
The vertical tail tip needs a new clear coat, so that is all that is left to do.
Right tail tip repaired and clear coated.
Left tail tip clear coated.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
