Brief Description: Canopy holes at pilot-side - 2 of 2
- Removed the taped-on strap, and drilled 4 holes per the marks made.
- Cleco'd the strap to the canopy via those 4 holes.
- With the canopy held in place against the frame, drilled the remaining pilot holes. You MUST make sure to press the canopy material in when doing this, as the canopy changes shape and spreads out when pressed against the frame.
- The photo shows all the pre-drilled holes transferred from the strap to the canopy material.
There are still a few more holes to locate and drill, that go into the canopy frame corners.
