My day job has gotten crazy busy. Both a blessing and a curse. Hence my lack of progress over the last several days.
I sanded out the filler that I put on several days ago, on the upper cowl. There were still a few pits that had to be filled, so I added a little more filler to those spots (photo 1).
Then I added filler to the lower cowl (photo 2). A lot is required here simply because I made such extreme modifications to this area. But really most of the blue will get sanded off, except at the lowest points.
And then I added filler to all of the joints between the wheel pant halves (photo 3).
I also got some plastic scrubber pads to put in the air/oil separator that I made, and glued on the final cap. Now it's ready to use (no photo).
Filler sanded, then a little more added.
Lots of filler here, but most of it will get sanded off.
