Michaels Web Site
Sonex Standard Gear
Oil filler door
- By watching the shadow of my finger through the cowl (looking through the cooling inlet) I marked the location approximately over the oil filler.
- I drilled a pilot hole (photo 1) to verify that the filler was centered below.
- Then I used the Dremel to cut out the flat-sided opening (photo 2).
- After sanding all the edges I put it over the engine and it aligned perfectly.
Pilot hole to verity location of filler below.
Rough cutout, per plans.
Finished cutout, with cowl over engine.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
