Michaels Web Site
Sonex Standard Gear
Plumbing the smoke system
Plumbed the smoke system from the smoke pump to the 2 lower exhaust pipes. The friction fittings made the whole process really easy.
Smoke line plumbed to the bung that was welded to the lower exhaust pipes.
Fuel line is left. Foreground & right are the lines plumbed from the smoke oil pump.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
