Michaels Web Site
Sonex Standard Gear
Oil cooler baffles
Worked on fitting the upper section of the oil cooler baffle. I needed to make a considerable number of small cuts, a little at a time, to get it to fit around the engine case and case bolt. It's pretty much there, now.
Upper oil cooler baffle, viewed from below.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
