Michaels Web Site
Sonex Standard Gear
Transponder static connection
The static line needs to go to both the transponder and the EFIS, so I needed a Tee fitting. The static line to the transponder is narrower than the one to the EFIS, so I had to buy a tee fitting that had two 1/4" ends and a single 1/8" end.
Tee fitting to the left of the word "STATIC"
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
