Brief Description: Still working on clip replacement
- I reset the valve-to-rocker arm clearances on the 1 & 2 cylinders that I'd already worked on. Took me a couple of tries to get it right.
- Then went to the other side and removed the other 2 cylinders.
- When I was loosening one of the 8 nuts, the stud spun with the nut! The threaded insert in the block is not spinning, but the bolt is, and it's noticeably looser laterally than the rest. I've asked Sonex about it.
- I would have replace the cylinders tonight but it was getting late, so I'll save it for when I'm fresh.
