Michaels Web Site
Sonex Standard Gear
More fiberglass on cowl
Added fiberglass to the lower portion of the cowl. This time I used peel-ply (light green in the photo) so I could use a scraper to smooth out the glassing. This should give a smoother finish with less resin.
More fiberglass. Peel ply is light green.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
