Michaels Web Site
Sonex Standard Gear
Wiring...
- Ran some wire bundles through the recently installed Click Bond supports.
- Also used one Click Bond to support the static and pitot tubes, and the fuel sight guage tubing.
- Made one end of the shielded P-Lead wires and attached them to the panel switch. Cut both to length on the engine-side of the firewall.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
