Michaels Web Site
Date:  5-23-2013
Brief Description:  Wire bundles + fuel sight tube
- Had to reconnect the passenger PTT wires, since I'd run them around the rudder cable. Oops.
- Used wire ties and tie string to bundle the wires of the comm harness (photo 1). Makes things much neater and easier to handle.
- Started installing the fuel sight tube. Connected one end to the tank fitting (photo 2) with a clamp, then ran the tube through grommets in the instrument panel (photo 3).
Wires tied into bundles
Top end of fuel sight tube attached to tank fitting.
Fuel sight tube
Fuel sight tube
