Michaels Web Site
Sonex Standard Gear
Panel rivets + wiring
- Riveted the right side panel into place.
- Re-ran and re-attached the cabin heat cable (it had to be removed to paint the panel)
- Began to route the wiring that comes through the firewall, to where it will end up at the panel.
Right side of panel riveted in place.
Beginning of routing wiring to panel.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
