Michaels Web Site
Sonex Standard Gear
Paint instrument panel
Prepared and painted the instrument panel with crinkle paint.
- Roughed up the surface with medium sandpaper.
- Cleaned with an air hose, then mineral spirits. Let dry.
- Instructions say to put on 3 VERY thick coats, installing each coat 5 minutes apart.
The paint crinkles after several hours.
Pieces are very wet after 3 coats.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
