Michaels Web Site
Sonex Standard Gear
Started glassing the upper cowl
- Cut short strips of fiberglass mat
- Roughed up the surfaces to be fiberglassed, with 80 grit sandpaper. Blew clean with air hose, then cleaned with mineral spirits and let dry.
- Installed overlapping glass strips, avoiding the clecos holding it together.
Strips of fiberglass mat cut and ready to install.
Roughed up the surfaces to be glassed.
Horizontal strips of glass, missing the clecos coming through.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
