Michaels Web Site
Sonex Standard Gear
Partial fiberglass lower cowl halves
Started fiberglassing the lower fuselage halves together. The engine/mount are in the way of doing the whole thing, so hopefully this will be enough to hold it together so I can remove the whole thing and fiinish on the work bench.
At prop hub
Lower cowl, below engine mount
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
