- Did some more trimming of the left cowl to get it to fit with the fuselage and with the right cowl half.
- Then cut the cowl horizontally as I did for the right cowl.
In photo 3 you can see the 4-way split in the cowl. Once I get everything fitted I'll fasten the right/left halves together and then fiberglass them into a single bottom cowl and a single top cowl
Tomorrow I will begin adding the hinge half to the lower and upper cowl pieces.
