Michaels Web Site
Date:  3-20-2013
Number of Hours:  1.25
Brief Description:  Continue fitting left cowl
- Did some more trimming of the left cowl to get it to fit with the fuselage and with the right cowl half.
- Then cut the cowl horizontally as I did for the right cowl.
In photo 3 you can see the 4-way split in the cowl. Once I get everything fitted I'll fasten the right/left halves together and then fiberglass them into a single bottom cowl and a single top cowl
Tomorrow I will begin adding the hinge half to the lower and upper cowl pieces.
Top cut off of left cowl
Left cowl in place with duct tape at fuselage
You can see the 4-way split in the cowl.
