I will need to do some fiberglass work: 1. To extend the back edge of the upper cowl to meet the windscreen (I cut away a little too much when I was trying to fit the cowl per instructions.
2. At the intakes, where there is a little separation between the halves. Not much, though.
Next I need to drill the 10 holes in the bottom of the stainless firewall, to take the hinge that holds the cowl there.
Top and bottom cowls together
There is some fiberglass work required here, to fill the gap, but not too bad.
I put the left cowl loosely in place just to see how it fit. This is just loosely laid in place.
