Michaels Web Site
Sonex Standard Gear
Baffles & cowl
No work over the last week. I was on a golf trip! Now I'm back to work.
Spent time finishing some of the complicated cuts on the engine baffles by using the band saw, then filing and sanding smooth.
Keith Macht made me a perfect prob hub spacer on his CNC machine! So I bolted that onto the prop hub so I can start work on the cowl.
More baffle bending
Prop hub spacer for cowl installation
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
