Michaels Web Site
Sonex Standard Gear
Rear baffle
These photos show the work after the posterboard (see other entries with today's date), working with the actual aluminum baffle material.
If you see the blue marks, that is what was initially cut away.
The actual baffle being test fit and tweaked.
View from the left rear
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
