Brief Description: Finally got the last engine mount screw in!
Actually, I got the screw in, but there was not enough room between the mount and the gear leg to get the nut on straight, and NO threads were showing on the other side of the nut.
So I decided to drill a third hole in the engine mount bracket, into the engine mount. There was just no other way to get the gear secured. So there are two good bolts, and one so-so bolt on this one engine mount bracket.
