Michaels Web Site
Sonex Standard Gear
Terminal block install
Installed the avionics terminal block inside the cockpit. The power from the avionics switch will come here, then go to all the avionics. Spent the rest of the time visualizing wire paths.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
