Michaels Web Site
Date:  11-12-2012
Manual Reference:  AeroVee
Brief Description:  Misc
Tried to put the intakes on, but again there were 4 studs that had to be "trimmed" almost down to the nuts.
In photo 1 you can see the studs in the way, but I also have the intake on the wrong side of the engine. The instructions don't tell you which intake is which, and they don't tell you that when mounted the intakes should angle down toward the fins, instead of away. It "looks" right, either way.
I had to cut the 4 studs almost down to the nuts to get the intakes to fit.
Found I am 1 nut short, so I only got 3 of the 4 nuts onto the intakes.
I also did some work to secure the cockpit light wiring.
Yes, I have the intake on the wrong side, but either way the studs stick WAY out and need to be cut.
Tape up all the orrifices before cutting.
One intake in place.
