Michaels Web Site
Sonex Standard Gear
AeroVee
Assemble crank case
Photo #1: Installation of a thin layer of Permatex Form-a-Gasket #3 on all mating surfaces.
Photo #2: Another (blurry) view of the case with the Permatex.
Photo #3: The case halves assembled and all the nuts and bolts installed and torqued.
Cylinders are next!
Permatex Form-a-Gasket thinly applied to the mating surfaces.
A slightly blurry shot of the Permatex.
The case halves assembled and all the fasteners set and torqued.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
