So I got started on it tonight. Problem is, I'm still crazy busy at work so no idea how much time I can actully put in for a while longer.
Note: I wimped out and paid for the option to have the prob hub mated by Sonex, instead of me doing it. So in photo 2 you can see it already in place at the right.
Photo 1: Connected the cam shaft with the cam gear with 3 bolts, Loctite'd and torqued.
Photo 2: Connecting rods installed, Loctite'd and torqued.
Photo 3: Closeup of connecting rodsn on crank shaft.
Cam and cam gear
Piston rods installed (note prop hub already in place)
