Michaels Web Site
Sonex Standard Gear
n/a
Wing tip light
Haven't worked on the project in a while. My job has been getting in the way!
- Soldered the wires for the wingtip light on the right wing. All connections got heat shrink as well.
- Attached the pod with the light, and there we go!
- Also finished painting the rivet heads, and polished used polishing compound to polish all the underside painted surfaces.
Wires soldered and with heat shrink tubing
Close-up of heat shrink
In place
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
