Michaels Web Site
Sonex Standard Gear
n/a
Overflow pan
- Applied the last coat of clear coat to the wing tip.
- Added a stainless steel patch over the hole that the overflow tube comes out of. After it dries I'll add fire caulk. Photo #2.
- Installed a bead of fuel proof sealant (unfortunately it's black) at the gaps around the overflow pan, including around the filler neck (photo #3).
Last coat of clear on this wingtip
Clamps holding ss patch in place (hard to see here)
Black sealant at joints
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
