- Continued working on the fuel filler overflow pan. Drilled and counter sunk a hole in the "pan" for the drain tube. Drilled a hole in the side of the fuel filler box to run the drain tube out (photo #1).
- Took apart and cleaned all the parts that make up my removeable instrument panel (photo #2).
- Drilled the 5/8" hole in the upper right side of the instrument panel, for the fuel sight guage (photo #3).
Overflow "pan" resting above; hole in filler box side, below.
Instrument panel parts getting ready for paint.
Hole in instrument panel for upper end of site guage.
