Michaels Web Site
Date:  2-26-2012
Number of Hours:  1.50
Manual Reference:  n/a
Brief Description:  Control stick grips & PTT switches
- I have the stick grips. They come with a PTT (push to talk) button at the top, but you have to do the soldering and strain relief, then scew them in place in the grip cap. Photo #1 shows the grip cap with the two 22ga wires after being soldered in place. The wires run down the stick tubes and out a small hole at the bottom that I added yesterday.
- Photo #2 shows one grip done, and the other with the grip cap in place with a set screw, and ready to slide the grip handle up to the cap.
- Photo #3 shows the completed dual-control assembly, ready for installation.
Actually, the wires for the PTT switches were not long enough to reach out the bottom of the stick, so I will get some more wire and connect to the ones from the PTT switch. Everything will get shrink tubing. The grips come off easily, so once I get the additional 22ga wire I'll do that work.
PTT switch in place in the grip cap, with wires through control stick. Set screw hole visible.
Far grip fully installed. Near grip with cap in place and set screw, ready to slide grip up.
Completed assembly
Completed assembly
