Michaels Web Site
Sonex Standard Gear
F06
Glare shield & Instrument panel
- Installed one more floating nut plate on the instrument panel. I'm two-short, so used clecos for now, until I get more.
- Located and drilled to secure glare shield
- Made second hinge halves for the center (removeable) instrument panel, including removeable bent hing pins (like for seat pan).
- Located and pilot drilled all holes on the 3 top edges of the instrument panel.
In progress: locating and drilling for panel
All holes in the glare shield, inst panel & panel hinges
Closeup of hinges holding inst panel in place
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
